Forums >> Revit Building >> Technical Support >> title block parameters
Wed, Dec 17, 2003 at 9:30:16 AM | title block parameters
Bimman
Bimman Avatar
1 Stars: 2 Votes
when inserting label parameters in my titleblock, how do you create new label pararmeters that are diiferent from the box shipped names so they appear on the drawing sheet list. i.e. plot date, revised date, we use different wording from what they ship. do i need to use what they ship or can i change them. i would think you can add them but i may be wrong. thanks in advance pete
Wed, Dec 17, 2003 at 12:15:29 PM | RE: title block parameters
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
yes, you can use different wording if you like. when you go to place the label a box will pop up entitled "select parameter" if you're doing a date stamp then chose the date/time stamp. If you don't want the time to show, delete it from the sample text... you can use a text note to specify it as a plot date or revised date. It would help a lot if I knew exactly what you are trying to do...
Hiroshi Jacobs
Wed, Dec 17, 2003 at 2:12:17 PM | RE: title block parameters
Bimman
Bimman Avatar
1 Stars: 2 Votes
i fiddled with so much this morning i figured it out. what i was needing to have happen was when i made a sheet index, i wanted the parameters i made to show up as fields that i could list on my index schedule. i did it by making new groups then setting parameters and they then were in my label choices which became my fields in the index.
Wed, Dec 17, 2003 at 2:20:43 PM | RE: title block parameters
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
So you were setting up a sheet schedule in your titleblock? Perhaps I misunderstand what you were saying... :-)
Hiroshi Jacobs
shared parameters vs lables on a title block
Tue, Feb 8, 2011 at 2:30:45 PM
project title block
Tue, Dec 1, 2009 at 2:18:45 PM
Font on Title sheet absent from project Title Block
Thu, Sep 15, 2022 at 12:31:26 PM
Shared Parameter In Annotations
Tue, May 22, 2018 at 5:44:20 PM
Title Block Labels
Wed, Feb 14, 2007 at 11:52:49 AM
Page generation time: 1.1994
