Forums >> Revit Building >> Technical Support >> Can I cut a hole through an extrusion?
Wed, Apr 11, 2007 at 8:51:58 AM | Can I cut a hole through an extrusion?
DaveF
HiI created an extrusion vertically (think long thin wall) that I want to cut a hole into the the extruded side. Is this possible?When I try editing it in elevation using either voids or lines, it tells me I have to change view (to plan).Is there a way around this?The reason I used extrusion is it's an existing wall that's a bit wibbly-wobbly (that's the technical term) in plan.Any help would be appreciated.CheersDave F.
Wed, Apr 11, 2007 at 9:00:54 AM | Can I cut a hole through an extrusion?
DaveF
Sorry, the formatting seems to have dissapeared & I can't find a way to edit my post.
Fri, Apr 13, 2007 at 8:31:51 AM | Can I cut a hole through an extrusion?
Jhui
Go to the floor plan view and set a reference plane along the edge and then give it a name ( right click - properties )
Then go back to the elevation and select that newly made reference plane as the reference.  If you need something more detailed, ask and I'll try to be more specific.  But long and short of it is right here.
re-joining (?) cut extrusion with extrusion
Tue, Apr 17, 2007 at 10:26:27 PM
Cut a void from an extrusion
Thu, Feb 19, 2015 at 1:08:44 AM
cutting a hole in a massed floor/roof
Mon, May 11, 2009 at 7:07:00 AM
Void Extrusion Constraint
Tue, Apr 11, 2006 at 9:03:58 PM
Void Won't Cut Extrusion
Wed, Feb 13, 2013 at 11:04:26 AM
Page generation time: 1.3441
