Forums >> Revit Building >> Technical Support >> Railings beyond cut plane
Tue, Apr 10, 2007 at 10:48:34 AM | Railings beyond cut plane
39lavoie
I have a very basic fire egress stair.  The handrail located against the wall is visibly backwards in plan.  Every other view is correct, but in plan the railing that is within my cut plane has gone dashed and what is beyond the cut plane has gone solid.  The railing located along the core in the same run does not have this problem.  Has anyone ran into this problem before and have you found a fix.  I'm using version 9.0.  Thanks
Tue, Apr 10, 2007 at 11:16:18 AM | Railings beyond cut plane
Cut a section through this stair and look at this railing.  If it lost it's host and became flat with the landing, it would look like this.
Tue, Apr 10, 2007 at 11:32:52 AM | Railings beyond cut plane
39lavoie
The section is correct  As stated in the post, all other views are correct.  The plan visibility is the only thing wrong.  Also, it has been my experience that if the railing is flat (unhosted), than it will either show all solid because it's within the cut plane or it will not show at all, not even dashed above.
Cut Plane display issue
Tue, Oct 11, 2011 at 12:48:42 PM
Would like shadows to appear from above cut plane
Wed, May 2, 2012 at 1:22:44 PM
How to control where the cut plane is for families?
Sun, Nov 22, 2009 at 10:19:59 AM
high windows and cut plane
Mon, Mar 19, 2012 at 10:15:29 AM
Cut Plane as a parameter
Fri, Apr 17, 2009 at 12:37:12 PM
Page generation time: 0.3311
