Forums >> Revit Building >> Technical Support >> Toposurface, Shared Coordinates, and Contour Labels - Need Help Fixing
Fri, Apr 6, 2007 at 3:28:25 PM | Toposurface, Shared Coordinates, and Contour Labels - Need Help Fixing
seltied
Hello Everyone,
Can anyone provide some insight into how to control the interaction between shared coordinates, topography, and labeling contours? The circumstance is that I have a toposurface in place, under my building. It's a complex terrain, with a spread of about 60ft from the lowest to the highest contour, and I created it by using the "Import Instances" from an ACAD file.
When I use the shared coordinates command and assign Level 1 (in elevation) as 40.71 ft, everything looks great, until I hit "Edit" on the toposurface. For some reason, the shared coordinates are not working on the points themselves. Each point on a contour line has an Elevation of 0.29, the next contour up has points all at 1.29, the next one 2.29, and so forth. But when I slap "Label Contours" on them and use Shared Coordinates, they come out correctly: 40ft, 41ft, etc.
This is a problem, because I don't want to do the math every time I want to add contours.  My civil will be working on it too, and I want it to be right for him.  I don't want to move the toposurface up or down without also moving the building. I just want the points that make up the toposurface to read correctly: 40ft, 41ft, and 40.5 ft if need be.
Thanks for any help anyone can provide.
Edited on: Fri, Apr 6, 2007 at 3:30:18 PM
Wed, Aug 31, 2011 at 5:29:12 PM | Toposurface, Shared Coordinates, and Contour Labels - Need Help Fixing
ljaccaud
I see that this is an older post.  But I was wondering if you ever figured it out?
Toposurface - CSV import to shared coordinates
Thu, Aug 22, 2013 at 2:59:54 PM
Possible to place contour lines to toposurface instead of points?
Fri, Jun 1, 2018 at 2:57:52 PM
Contour labels
Mon, Feb 8, 2010 at 7:42:35 AM
contour labels inverted
Fri, Mar 2, 2007 at 2:55:34 PM
toposurface
Tue, Sep 5, 2006 at 6:03:12 AM
Page generation time: 0.1431
