Forums >> Revit Structure >> Technical Support >> Design Option Underlay
Fri, Apr 6, 2007 at 2:06:03 PM | Design Option Underlay
SamIAm
I am the last person in my firm to begin using Revit and am fumbling through to the best of my abilities.  Hopefully this query won't show my ignorance.  I have been using the Design Option feature and so far its been great.  But recently I've realized that when in the second floor plan, the underlay is showing up incorrectly.  During normal editing the underlay shows as the first floor for that design option but when I lay all of the options out on a sheet and then begin editing one, suddenly they all have the same (incorrect) underlay.  I've checked the properties and indeed, the underlay is the first floor for the first option I drew (not the same one that shows up when viewed simultaneously on a sheet).  When I try to change the underlay, the only other options available are the other levels of that first design option, and none of the levels for the option I'm actually working on are available.  Its not really causing a problem because during normal design option editing the correct underlay shows up.  But I'm afraid that, once deeper into the project, it will cause major problems.  What's going on?  Anyone?
Design Option Issue - walls in 1 design option cutting thru a 2nd option
Thu, Oct 21, 2010 at 11:55:04 AM
Design Option view setting
Fri, May 16, 2014 at 8:02:11 PM
Design Options - black hole.
Wed, Feb 14, 2007 at 12:54:40 PM
Design Option Sharing
Mon, Dec 6, 2010 at 10:02:19 AM
12
Railing wont host to stair created in design option
Mon, Oct 24, 2011 at 3:54:39 PM
Page generation time: 1.9881
