Forums >> Revit Systems >> Technical Support >> MIRRORING OR FLIPPING A WHOLE PROJECT IN REVIT
Thu, Apr 5, 2007 at 4:36:33 PM | MIRRORING OR FLIPPING A WHOLE PROJECT IN REVIT
bldrsdesign
TO OTHER REVIT USERS,
I HAVE PROJECTS THAT I WOULD LIKE TO BE ABLE TO HAVE THE REVERSE OF. DOES REVIT HAVE AN EASY WAY TO FLIP A WHOLE PROJECT? ELEVATIONS, FLOOR PLANS, FLOUNDATION, SECTIONS AND ALL.? ATTEMPTS THUS FAR HAVE DELETED ELEMENTS OR ONLY REVERSED SOME OF THE ITEMS. IT WOULD BE COOL TO HAVE A ONE STEP OPTION... AM I DREAMING?
IF ANYONE HAS A METHODE PLEASE LET ME KNOW. THANKS FOR YOUR TIME.
JED
Fri, Apr 6, 2007 at 6:23:35 AM | MIRRORING OR FLIPPING A WHOLE PROJECT IN REVIT
coreed
coreed Avatar
4 Stars: 16 Votes
these two links just about sums it up when it come to mirroring projects
http://www.revitcity.com/forums.php?action=viewthread&thread_id=3767
http://www.revitcity.com/forums.php?action=viewthread&thread_id=167
 HTH
Edited on: Fri, Apr 6, 2007 at 6:24:30 AM
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wed, Jun 4, 2014 at 9:04:51 AM | MIRRORING OR FLIPPING A WHOLE PROJECT IN REVIT
briggsb1
I've mirrored a project... a large project (Architecture) and as I went throught the project, I made a list of all the thing that I ran into as far as cleaning up the construction documents after.
It turns out, it's not just a one click deal.
http://myselfishthoughts.blogspot.com/2014/04/revit-mirroring-large-project.html
Wed, Jun 4, 2014 at 9:26:37 AM | MIRRORING OR FLIPPING A WHOLE PROJECT IN REVIT
Your linked thoughts is a good post.
BTW - This thread that you posted in dealt with mirroring a project before the mirror project tool.  The mirror project tool was a good advancement but as you point out, there are still things the user has to check out.  That is why in the HELP they warn you "In some cases when you mirror a project, relationships between elements are not supported as in the original orientation of the project. This can lead to unexpected results and errors, for example some elements may deviate from exact reflection. After you mirror the project, a message displays to indicate any errors encountered. You can export errors to review and correct them."
Flipping a building
Fri, Nov 11, 2005 at 2:56:01 PM
Mirroring
Mon, Oct 14, 2013 at 4:28:29 PM
Wall hosted components in groups............
Fri, Nov 3, 2006 at 8:09:00 AM
13
Mirroring House model
Wed, Oct 27, 2004 at 4:33:14 PM
Mirroring an entire project
Mon, Feb 16, 2009 at 8:45:08 AM
Page generation time: 4.4527
