Forums >> Revit Building >> Technical Support >> Display Issues with 3D CAD data
Thu, Apr 5, 2007 at 2:32:18 PM | Display Issues with 3D CAD data
DJKell
I am working on a project with a structural engineer who has given me a 3D model of the structural steel in CAD.  The data imports fine adn displays correctly in plan views once the model has been partially exploded.  That is, I see only the structural items visable on that level.  (Prior to exploding I could see roof structure on the first floor plan.)  However, when I cut a section at a stair, for example, I am seeing structure that is BEHIND the cut line.  I cannot find any logical reason to be seeing this information in this view.  Structure that intersects the cut line displays as you would expect it to.  I've checked visability graphics and the view properties but do not see anything that looks like it would pertain to this issue.
Any help wleaning up this issue would be appreciated.
-Kell
Sample REVIT FILE NEEDED w/ AUTO CAD DWG DATA
Tue, Feb 2, 2010 at 2:34:51 AM
display issues
Wed, Apr 1, 2009 at 6:19:32 PM
Revit Identity Data export to Navis
Tue, Aug 30, 2022 at 6:23:11 AM
Wacky Cad file line display
Wed, Nov 13, 2013 at 12:05:33 PM
Importing CAD File - Not Appearing
Wed, Apr 4, 2012 at 4:22:24 AM
Page generation time: 0.6195
