Forums >> Revit Building >> Technical Support >> room system families: adding identity data
Wed, Apr 4, 2007 at 4:23:37 PM | room system families: adding identity data
pgrimmi
Hi folks, does anyone know if it is possible to add identity data that can be shown in room tags? similar to attributes in autocad. the project i have has a 5 letter code for each room and i would like to show that on the room tag!
Wed, Apr 4, 2007 at 4:55:12 PM | room system families: adding identity data
TomDorner
4.5 Stars: 25 Votes
Yes it can. Simply edit the room tag family and you can add any field from the standard room properties to the tag. You can also have multiple versions of rooms tags. Think of the tags as 'reports' that can show any of the properties of the room. Your task is to figure out if you can use one of the existing fields to hold your 5 digit code. The 'department' field would be a logical choice. If you need to add a field, then you have to do it via shared parameters. Using shared parameters should not be undertaken without proper understanding of them so I would keep it simple and keep to stock room parameters for now.
Here is an old one I had from a previous employer you can use for an example.
Edited on: Wed, Apr 4, 2007 at 5:00:51 PM
Tom
www.reviteer.com   http://twitter.com/Reviteer
Tue, Aug 5, 2008 at 5:24:14 PM | room system families: adding identity data
Bimmer32
How do you add additional identity data parameters to the room family (system) instead of the room tag family?
Adding formula to change identity data and heights of components
Mon, Oct 21, 2013 at 5:02:09 AM
Copy room identity Data
Fri, Apr 5, 2013 at 9:02:41 AM
Editing existing Identity Data in a Family
Tue, Sep 22, 2009 at 12:34:42 PM
Identity Data
Thu, Oct 6, 2005 at 10:21:03 PM
identity data locked
Fri, Apr 8, 2011 at 3:08:50 PM
Page generation time: 0.5561
