Forums >> Revit Building >> Technical Support >> Wall Modification
Wed, Apr 4, 2007 at 2:31:01 PM | Wall Modification
ebtaylor
3 Stars: 2 Votes
I have recently looked into the modify commands within the wall structure. I have done something to my wall and one, don't know what I did, 2nd I don't know how to fix it.
The only command I actually used on this way was the modify where I unlocked my exterior material and moved it down. As you can see now I have a void in my and not sure how it got there.
attached is an image
thanks
Thu, Apr 5, 2007 at 5:38:16 AM | Wall Modification
Sparky
5 Stars: 3 Votes
That looks like a wall sweep or reveal to me.
In the same view that youve posted, have a look under the "Reveal" and "Sweep" buttons wether something has slipped in (just delete the instance in the table if you dont want anyting there)
Hope that helps.
DAR
Edited on: Thu, Apr 5, 2007 at 5:39:14 AM
Brick & frame wall modification
Mon, Oct 13, 2008 at 3:22:31 PM
Schedule modification
Fri, May 14, 2021 at 10:43:58 AM
L-Angle Modification
Wed, Jan 7, 2009 at 2:57:14 PM
NewBie - Wall dimension tips
Sun, Apr 9, 2006 at 3:27:32 PM
Ceiling grid modification Not happening help
Sun, Jan 8, 2012 at 8:19:11 AM
Page generation time: 5.3859
