Forums >> Revit Building >> Technical Support >> Rotating Sweep Families
Wed, Apr 4, 2007 at 10:28:49 AM | Rotating Sweep Families
Enginator
5 Stars: 2 Votes
I'm trying to create a family that can be rotated in any plane.  The family is comprised of sweeps.  So far, after it is imported into the project, I can only rotate it in the Ref Level view.  When I try to rotate in any other view, I get a "can't rotate into this position" error.  I've also tried setting up labeled angular dimension on the sweep profile, but it doesn't seem to like rotating the sweep in any other plane that the top view of the family either.
Rotating Symbol geometry without rotating leabel
Wed, May 6, 2009 at 8:33:58 AM
Rotating mullions
Thu, Jul 24, 2008 at 4:27:53 PM
Can't Create Sweep
Wed, Sep 20, 2006 at 2:39:47 PM
Rotating Views On a Sheet [ 1 2 ]
Tue, Jun 17, 2008 at 12:49:46 AM
18
Rotating Families in elevtion or Section, Can it be done?
Fri, Sep 26, 2008 at 12:19:51 PM
Page generation time: 0.5015
