Forums >> Revit Building >> Technical Support >> Arraying symbolic lines
Tue, Apr 3, 2007 at 6:35:07 PM | Arraying symbolic lines
puzzle
4 Stars: 10 Votes
I have made a fold out clothes line. The model works fine but I have been trying to add symbolic lines for the hanging lines in plan view. I don't know what I am doing wrong but I can't seem to get the lines to array & stay constrained to the length. It should be simple but I don't know what I am missing.
Thanks
Macca
Sunshine Coast
QLD Australia
Mon, Apr 9, 2007 at 5:26:41 AM | Arraying symbolic lines
Pragati
Pragati Avatar
Hey!
As you said it was quite simple. You were on the right track by nesting a line family and arraying it but always remember, when in a lengthier array get the second member to last point by checking last option...
next step is select the item brought to the other endi and go to edit group , pick it again and align it to the references - horizontal and vertical . this way you ensure that you have both your guides of the array behaving well so that rest of the array members follow the alignment too. Only one member alignment does not suffice. and always try to nest array components. In place solida are troublesome.
Attached is the array group that i completed in your family.I tested it too and it works fine..Try using detail lines for plan representations..as model lines show up in 3D until and unless you want them to show up.
All the best
Pragati
Mon, Apr 9, 2007 at 5:18:16 PM | Arraying symbolic lines
puzzle
4 Stars: 10 Votes
Thanks for the help.
Macca
Sunshine Coast
QLD Australia
Symbolic Lines and Model Lines
Wed, Mar 22, 2006 at 12:52:17 PM
symbolic lines
Thu, Jul 13, 2006 at 8:15:41 PM
Symbolic lines
Tue, Dec 26, 2006 at 2:24:22 AM
Windows above the Cutplane and Symbolic Lines (Revit2010)
Wed, Jul 14, 2010 at 7:35:42 AM
Symbolic Lines Variation in Family
Thu, Feb 15, 2007 at 1:33:21 PM
Page generation time: 2.2293
