Forums >> Revit Building >> Technical Support >> Sheet Issue Date Format
Tue, Apr 3, 2007 at 4:30:55 PM | Sheet Issue Date Format
daleyy
When I insert my titleblock, the sheet issue date is not formated to our standards. It shows up like 04/03/07 when we want it to read April 3, 2007.
How can I format that label in the titleblock to comply with our standard?
Thanks
DaleW
Tue, Apr 3, 2007 at 5:05:49 PM | Sheet Issue Date Format
TomDorner
4.5 Stars: 25 Votes
The sheet issue date is a simple text field that is in the properties of the titleblock.  You can type in anything you want.  I believe it is initially populated via reading your Windows system date in the form of mm/dd/yyyy.
Tom
www.reviteer.com   http://twitter.com/Reviteer
Tue, Apr 15, 2014 at 7:21:31 AM
"Sheet Issue Date" - Bug
Mon, Jun 6, 2011 at 12:06:58 PM
Current Revision Date in sheet index
Mon, Nov 2, 2009 at 11:22:28 AM
RAC 2010 How to change the date format in a drawling list (NOT TITLEBLOCK!)
Wed, Feb 24, 2010 at 9:22:04 AM
Revit 2013, Issue Date Question
Thu, May 2, 2013 at 4:16:13 PM
Page generation time: 0.3338
