Forums >> Revit Building >> Technical Support >> 3d sweep
Tue, Apr 3, 2007 at 12:34:06 PM | 3d sweep
send2lewis
What I want to do is to create a 3d path in a sweep.  The only option for the path in a sweep is 2d.  I'm doing a staircase with only one cylinder steel support at the center, it's in a "L-shape".  So, is Solid Sweep is the only way to draw this tube? or there's other easier way? have anyone done this before?
The attached drawings is what I did, but it's not accurate.  What I did is I break it up into sections inorder to rotate the curve parts.
Tue, Apr 3, 2007 at 3:13:42 PM | 3d sweep
TomDorner
4.5 Stars: 25 Votes
You can pick the path for a sweep in 3D.  I use a mass or voids in comination to create an edge curving through 3D that can be selected.
You may also try using the stair generator and pick a circular profile for a stinger to get what you are after.
Tom
Can You Flex a Sweep in Components
Mon, Jun 3, 2013 at 2:09:23 PM
Sweep Profiles in Version 9
Thu, Aug 3, 2006 at 2:14:05 AM
How to cut an arch into a sweep
Thu, May 26, 2022 at 4:02:08 PM
Sweep and Sweep/Blend Component
Mon, Apr 23, 2012 at 12:36:52 PM
Wall sweep splitting/joining
Sun, Oct 19, 2008 at 1:29:46 PM
Page generation time: 1.7255
