Forums >> Revit Building >> Technical Support >> Roof with two slopes?
Mon, Apr 2, 2007 at 5:02:26 PM | Roof with two slopes?
Solopk
I am wanting to achieve a roof that starts with a 6:12 pitch and then goes to a 12:12 pitch (ref image).  I have created the roof by using two seperate sketches as you see in the attached image.  Is there a way to do this in a single sketch?  I want the line where the two meet to go away, and the shingle pattern to just carry up the roof.  This is a common design/ construction detail in French "style" homes.  Any thoughts on how to achieve this.  Thanks
Mon, Apr 2, 2007 at 5:32:31 PM | Roof with two slopes?
TomDorner
4.5 Stars: 25 Votes
Try joining the roofs with the join roof command or join geometry.  If the suface pattern is model based, use the align command to align the shingle pattern.
Tom
www.reviteer.com   http://twitter.com/Reviteer
Mon, Apr 2, 2007 at 8:19:03 PM | Roof with two slopes?
framerman
4 Stars: 13 Votes
Another way you might be able to get rid of it is using the linework tool and using invisible lines.
revit roof slopes
Tue, May 6, 2014 at 10:19:05 AM
Adding skylights and slopes to a roof
Thu, Jul 12, 2012 at 8:33:07 AM
roof issue (even roof valley slopes with uncentered drain locations)
Wed, Mar 14, 2012 at 12:25:14 PM
Roof Slopes
Fri, Sep 24, 2004 at 11:17:08 AM
13
roof slopes with skylight openings and notch
Wed, Apr 21, 2010 at 1:09:29 PM
11
Page generation time: 4.3506
