Forums >> General Discussion >> Wishlist >> How do you change the default grid layout when modeling ceilings?
Mon, Apr 2, 2007 at 11:42:08 AM | How do you change the default grid layout when modeling ceilings?
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
The standard assumption built in Revit is a real irritant!!  Revit automatically puts a grid intersection in the center of the room and runs the long dimension of the 2x4 grid with the long dimension of the room.  Both assumptions are almost always wrong in every room I do!  We ALWAYS run the long dimension of the ceiling tiles perpindicular  to the long dimension of the room.  That makes long narrow rooms look less narrow when the grid runs across the short dimension of the room. Therefore I have to rotate ALL of my grids once placed in the room.  Many times, I will have either a ceiling tile or a light fixture in the center of the room.  MOST of the time, I have to shift my grid one foot one way and two foot the other to get a grid panel centered in the room.  Is there anyway to change these defaults?
Thu, Jul 26, 2007 at 10:31:05 AM | How do you change the default grid layout when modeling ceilings?
danpecor
danpecor Avatar
In reflected ceiling plan view, you can select one of the grid lines and move it with the standard MOVE command.  This will move the entire grid in the direction and distance you enter.  Unfortunately, I have not yet found a way to align the grid shown in the ceiling tile material in a rendered view to match the plan view.  If anyone has done this, please let me know.
Tue, Feb 6, 2018 at 10:30:49 AM | How do you change the default grid layout when modeling ceilings?
ianvicious
Here is way to make ceilings automatically center the “tile” and not the “grid”.  This might save a ton of time nudging ceilings around.  JFYI.
Make a new material (or edit the existing acoustic ceiling material) then edit the surface pattern, and import this custom pattern file (attached) – when importing the model hatch, scale by a factor of 24 (for 24”x24” tiles). For 24x48 inch ceiling tiles, use the “centered 24x48” file attached. Scale by 48 when importing.
Also if you have already created your ceilings, this will retroactively change all the ceiling patterns if you change the ceiling type to have the new pattern.
grid layout
Mon, Feb 21, 2011 at 7:40:24 AM
changing grid lines angle - walls are detached
Fri, Apr 20, 2007 at 6:29:43 PM
Any way to change the default settings for placing ceiling grid?
Tue, Apr 3, 2007 at 11:46:04 AM
Ceiling grid visibility
Mon, Oct 13, 2008 at 9:10:29 AM
Ceilings in Revit
Thu, Nov 15, 2012 at 4:10:07 PM
Page generation time: 9.9091
