Forums >> Revit Building >> Technical Support >> Editing Hatch Patterns
Mon, Apr 2, 2007 at 11:12:48 AM | Editing Hatch Patterns
Archeyes
I am trying to custom create a hatch pattern for use as a surface pattern for a certain project. The pattern is similar to on that RevitCity has available for download (24x4 running Bond Stone 3030) now instead of the 24 x 4 what I need to use is the 24" x 6" and the coarsing we are interested in needs to be offset 6" in every row.
Does anybody know if there are any pattern file editors out there, which will enable me to edit / create my own patterns visually. (without writing any code.)
Any direction would be much appreciated.
Thank you
Paras Nanavati, Assoc. A.I.A. HNTB Architecture
Mon, Apr 2, 2007 at 12:49:01 PM | Editing Hatch Patterns
framerman
4 Stars: 13 Votes
yessir. hatchkit seems to be what everyone likes. draw what you want on the screen and it does it for you.
after it creates your file, you might need to jump into the file editor and tell it to be a model hatch or drafting hatch. it's simple to do so don't worry too much about that.
You could also edit your existing one if it's not too complicated.
Mon, Apr 2, 2007 at 1:19:40 PM | Editing Hatch Patterns
Archeyes
Thank you Frameman.
I am in the process of creating my file in hatchkit 2.6. How do you get into the file editor and change the model hacth to the drafting hatch?
Tue, Apr 3, 2007 at 2:33:19 AM | Editing Hatch Patterns
Sparky
5 Stars: 3 Votes
To change the hatch type just edit your created file with a text editor.
DAR
Custom Hatch Patterns
Thu, Dec 23, 2004 at 3:00:32 PM
Hiding Hatch Patterns [ 1 2 ]
Sat, Aug 29, 2009 at 8:12:25 AM
15
imported acad hatch patterns
Sun, Nov 25, 2007 at 6:39:02 PM
Stone Hatch Patterns - Looking for a good source.
Sat, May 4, 2013 at 4:59:24 AM
How to Import Hatch Patterns
Thu, May 31, 2012 at 1:16:12 PM
Page generation time: 0.2696
