Forums >> Revit Systems >> Technical Support >> Underlay won't show up??
Mon, Apr 2, 2007 at 8:35:09 AM | Underlay won't show up??
hsaarch
I searceh the forum and couldn't find any help so I'm starting a new thread in the hopes somebody can help. I can't get the second floor to show up as an underlay for my roof plan. any ideas?
Mon, Apr 2, 2007 at 8:37:05 AM | Underlay won't show up??
Safety
1 Stars: 1 Votes
Set your view depth in view properties to the required level!
Mon, Apr 2, 2007 at 8:44:55 AM | Underlay won't show up??
hsaarch
I've been experimenting with the view depths for hours. I have the view depth set at the second floor right now and still not visible. I have other projects in the offcie that are working properly and have matched the settings and still no underlay..
Mon, Apr 2, 2007 at 9:48:13 AM | Underlay won't show up??
Sounds like your floor is on.  Turn that off.
Wed, Jan 9, 2008 at 8:03:07 PM | Underlay won't show up??
p1nkrose
I am having the same issue as well. It worked the first time I tried it, but just now it didn't show the correct level. When I go to second floor plan and overlay first floor plan, nothing shows up. When I overlay the second floor plan on the second floor plan just for the sake of it, the roof plan shows up. But I can overlay the second floor plan on the first floor plan. It seems that it ought to show the correct level. I don't know how this happened either. Turning wireframe works also, but I like to know how to fix the underlay to show the right level. Maybe it got confused between underlay and overlay.
Fri, Nov 7, 2008 at 4:30:14 PM | Underlay won't show up??
jimij
This is an old post, but I was having the same problem, turned out I needed to move the Primary range bottom up higher.
Sat, Nov 8, 2008 at 11:57:34 AM | Underlay won't show up??
4 Stars: 205 Votes
Hi, did you check "Discipline" and "Phase"???
Mon, Aug 29, 2016 at 11:39:28 PM | Underlay won't show up??
douggie66
Old thread I know but I've been stumped by this all afternoon and just found a solution that worked for me. In the end all I had to do was simply change Underlay to a different level and then change it back again to the level I wanted, in my case "Top Plate". Miraculously my underlay reappeared after an hour of troubleshooting.
Seems to be a niggly little glitch that pops up for no reason.
Wall won't show in North elevation
Thu, Oct 9, 2014 at 12:21:15 PM
Hatch Pattern in GYP ceiling won't show
Thu, Mar 12, 2009 at 10:00:42 AM
14
Underlay Properties
Sat, Sep 23, 2006 at 10:48:09 PM
Elevation won't show in preview and can't be printed out
Fri, Nov 20, 2015 at 10:58:59 AM
Underlay Issues
Wed, Mar 29, 2006 at 11:52:24 AM
Page generation time: 1.8366
