Forums >> Revit Building >> Technical Support >> Double Sided Fire-Place
Thu, Dec 16, 2004 at 12:47:31 PM | Double Sided Fire-Place
Osir
Has anyone seen/created/or thought up how to do a double sided fireplace? The tricky thing is obviously cutting two walls with one component. I thought to just do the surounding walls, firebox, chimney, and all as one single In-Place family, but this seems like a clunky work-around that might cause difficulties down the road. Anyone else?
-IOeser
Fri, Dec 17, 2004 at 10:48:37 AM | RE: Double Sided Fire-Place
Tanis
If you do not need an interior view or need to show the firebox, you could probably go to Create... Generic Model, then put your brick or stone material or patern as needed and specify the correct properties
Fri, Dec 17, 2004 at 12:20:33 PM | RE: Double Sided Fire-Place
Osir
Yes, I need to show interior elevations from both sides, as well as display the firebox in plan.
-IOeser
double sided lift
Fri, Jan 6, 2012 at 6:46:18 AM
double-sided fireplace
Thu, Apr 21, 2005 at 11:49:30 AM
Fire-tags
Thu, Apr 6, 2006 at 2:21:21 AM
Four sided gable roof
Wed, Apr 27, 2005 at 6:43:53 PM
formulas for fire rating.
Tue, Oct 14, 2008 at 8:24:03 AM
Page generation time: 1.9779
