Forums >> Revit Building >> Technical Support >> Solid Fill Hatch
Sun, Apr 1, 2007 at 8:56:31 PM | Solid Fill Hatch
RPM1000
Solid Fill Hatch Pattern is showing as spaced Diagonal Lines. Will not print as solid fill. Standard solid fill for other drawings is diagonals at 3mm crs, but this will not work in this particular drawing. If I reduce the spacing of the line properties to show solid fill on screen, the printer prints no hatch at all. Is there some setting elsewhere to correct this??
Solid fill and concrete hatch
Wed, Mar 28, 2012 at 3:19:54 PM
Solid Fill Hatch
Mon, Jan 18, 2010 at 11:40:09 AM
Lost Solid Fill Pattern
Wed, Apr 9, 2008 at 7:58:47 AM
Making solid hatch partly transparent...
Fri, Nov 9, 2007 at 4:00:06 PM
Solid Drafting fill pattern
Tue, Jun 23, 2015 at 1:35:01 PM
Page generation time: 2.7192
