14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> keynote text and leader alignment
136 Posts No Rating |
running version 9.1; when i keynote items, the leaders snap to other existing leaders, but i cant figure a way for the first letter of each keynote to align.   vertically) and for the leader to end in a particular spot. see photo; as far as i can figure its coincidence that the bottom two align the way they do and coincidence the top two align the way they do. id like to be able to pick one or the other. The list of notes looks quite messy; has anyone figured out how to align the text?
I'd rather be riding at whistler. or highland. thats good too.
45 Posts No Rating |
hopefully you've figured this out by now...but if not. I'm running RAC 2008, but I hope it's the same. When I annotate something with leaders I chose the leader option that allows me to place the elbow (two segments.) I then set the start point, the elbow point and then the length to the end of the leader line, then the text (either left or right justified.) Then each additional leader will align to both the elbow point and the end of the leader point.
i understand how that tect alignment works, my problem that i have run into again is when i am annotating a detail, i am using a mixture of text and keynote tags. i cannot get the edges of a text note and a keynote tag to align. any ideas??
Did you ever get a response to this issue that helped to fix it? Having the same problem here........
Leader origin for multi-line keynote text |
Thu, Jul 5, 2012 at 9:43:50 AM
keynote tag, crooked leader |
Tue, Mar 31, 2009 at 4:44:35 PM
Keynote Legend Not Showing Keynote Text |
Fri, Sep 6, 2013 at 11:40:59 AM
12
text box leader alignment |
Sun, May 9, 2010 at 7:48:44 AM
Leader and Keynote gap |
Mon, Nov 3, 2008 at 10:18:07 AM
