Forums >> Revit Building >> Technical Support >> Snap
Thu, Dec 16, 2004 at 12:32:42 AM | Snap
gY
Is it possible to draw at an angle less than 1 degree from the first point, I've tried turning off snap but still retricted to greater than 1 degree.
Thu, Dec 16, 2004 at 8:24:46 AM | RE: Snap
Bimman
Bimman Avatar
1 Stars: 2 Votes
the farther you are away from your start point of your line while still connected it will go smaller than 1 degree. in other wards when you are dragging it.
PWD
I can“t snap beam on grid lines
Fri, Dec 29, 2017 at 4:33:07 AM
Can not snap to linked files
Wed, Oct 31, 2012 at 5:42:48 PM
Can't snap to furniture in revit
Fri, Jan 27, 2012 at 9:02:35 AM
How to snap in 3D (not be constrained within current work plane)
Sun, Jan 27, 2013 at 12:51:47 PM
On sheet: cant snap to frame of drafting views
Thu, May 19, 2016 at 2:59:03 PM
Page generation time: 0.2708
