Forums >> Revit Building >> Technical Support >> Wall Tags not unique and not working correctly
Thu, Mar 29, 2007 at 2:37:09 PM | Wall Tags not unique and not working correctly
TesterSH
Hello, perhaps someone could help.  I've tagged the walls in plan for two different stacked walls but the tags want to show the same number.  I've checked each wall's contruction and they are close in nature but they were created as two distinct stacked walls.  (One element is the same while the other is different).  I then thought that it may have to do with the cut plane... but it is higher than the elevation of the lower (same) entity.  Any suggestions as to what I'm missing???
Wall Tags not unique for stacked walls [ 1 2 ]
Fri, Sep 16, 2016 at 10:17:50 AM
17
Need help with tags
Tue, Apr 20, 2010 at 3:21:03 PM
"Tag all not tagged" is not working
Wed, Jan 11, 2006 at 12:44:31 PM
WALL TAGS - VERY BASIC QUESTION
Fri, Apr 25, 2008 at 11:19:34 AM
Wall Join help - options not working [ 1 2 ]
Mon, May 11, 2009 at 10:22:05 AM
16
Page generation time: 2.3414
