Forums >> Community >> Newbies >> Notes: on sheet vs. in view
Thu, Mar 29, 2007 at 1:21:40 PM | Notes: on sheet vs. in view
tim1424
any feedback on which way is better?? I'm working on wall sections and am looking for feedback on what is the best practice.  This is my firms first revit project.
Thanks in advance!
Thu, Mar 29, 2007 at 5:38:47 PM | Notes: on sheet vs. in view
emaze
Place your notes in the view, never on the sheet.
Thu, Mar 29, 2007 at 6:54:40 PM | Notes: on sheet vs. in view
anthonyforlong
If your notes refer to multiple views on multiple sheets you can create them in a legend. Then place these on multiple sheets, really handy if they refer to more than one view, also saves you time if you need to edit them.
Fri, Mar 30, 2007 at 7:55:22 AM | Notes: on sheet vs. in view
tim1424
It was my first instinct to place notes in the view as well but what do you do when you have instances where you would like to draw outside of a scope box? (see attached image)
We place a box around our typ wall assembly description which you cannot do in the view if you are outside the scope box.
Any suggestions or thoughts?
Fri, Mar 30, 2007 at 4:51:24 PM | Notes: on sheet vs. in view
emaze
you really should be using a wall tag for that information; ie WA-2 (or whatever) for wall assembly 2, referenced to its general information somewhere in the front of the set.
Specification Sheet (Notes)
Sat, Dec 20, 2008 at 3:27:33 PM
RAC 2008 copy paste to transfer notes from views to sheet??
Wed, Aug 6, 2008 at 4:31:10 PM
General notes & vent calcs
Tue, Oct 11, 2005 at 6:15:04 PM
Keyed Notes in Drafting View
Mon, Mar 15, 2010 at 4:25:44 PM
Create Sheet notes symbol to add to sheet plan
Tue, Apr 14, 2009 at 4:07:25 PM
Page generation time: 1.9930
