6 Users Online (4 Members):
Forums >> Revit Building >> Technical Support >> Annotation - Floor Slope not in degrees
How would one make a annotation in revit that indicates the floor fall in example: " 1/100 " or "1/12" etc. Cant seem to find parameters for that! I only get degrees which I do not want to use! Some help please!!!!!
I must be missing something. Wouldn't you just be OK to type it in?
Finally figured that one out! TEXT Sometimes our brains just want use the difficult path! Instead of just using the obvious!! Silly ME!
46 Posts No Rating |
Under "Settings" then "Project Units" (or type UN) there is a options box at the bottom of that pop-up on the left side it says "Slope" then has a pull-down you can select "Slope Angle" or "Rise/12" HTH Jeff
Spot slope annotation problem - Revit 2013 |
Thu, May 2, 2013 at 8:44:26 AM
Roof Slope Annotation |
Tue, Apr 22, 2008 at 8:05:07 AM
Roof slope not showing up correct |
Thu, Jul 11, 2013 at 10:37:30 AM
Why does it say that my ramp has no slope when it does for a spot slope? |
Thu, Jun 4, 2015 at 2:02:14 PM
Floor drain slopes adding lines to the slope when modifying sub elements |
Tue, Oct 16, 2012 at 3:55:57 PM
