12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> Glass block surface patterns: how to adjust?
4 Posts No Rating |
Hello -- How (if possible) can I adjust a hatch surface pattern so that glass blocks appear in whole and not as partial blocks? I set up a 4" wide x 8" tall fill pattern, but I can't find a way to set it up so that the hatching begins at the bottom of the wall with a full 8" block. Currently it's centering the hatch pattern on the wall so that I have a 4" tall (partial) block at the bottom and the top of the wall. The wall is 8' tall so I should be able to hatch it with 12 complete blocks. Any ideas?
You should be able to use the Align command and align the pattern to your wall edge on both the horizontal and vertical. You can do this from an elevation view.
4 Posts No Rating |
Wow -- that was an easy fix! Thanks for the tip...it worked perfectly.
Glass Block Wall |
Wed, Apr 20, 2005 at 12:04:41 AM
Surface Patterns |
Wed, Mar 4, 2009 at 11:24:15 AM
Surface patterns |
Thu, Jan 31, 2013 at 9:11:08 AM
Surface Patterns in Perspective |
Fri, Jan 27, 2012 at 7:04:34 AM
Surface pattern move/align/adjust problems [ 1 2 ] |
Thu, Sep 17, 2020 at 10:29:33 AM
19
