Forums >> Revit Building >> Technical Support >> adjustable double door
Mon, Mar 26, 2007 at 9:15:37 PM | adjustable double door
austraw
I am looking for a double door where the opening angle is adjustable, like for a closet door. Should be such a basic thing, but I cannot find it. Tried to make it once, but the result was not flexing well...Thanks for your help.
Tue, Mar 27, 2007 at 9:15:00 AM | adjustable double door
rkitect
rkitect Avatar
4 Stars: 29 Votes
I had started working on this, but had some problems.  Just opened it up and hopefully fixed the problems I was having with it.  Let me know if it works ok for you!
Tue, Mar 27, 2007 at 9:22:51 AM | adjustable double door
austraw
just opened it up and adjusted the swing - works great so far. Thanks a bunch.
Tue, Mar 27, 2007 at 10:23:28 AM | adjustable double door
rkitect
rkitect Avatar
4 Stars: 29 Votes
Great!  The only thing you will notice about it is that the door panels must be the same width.  I'm sure it can be made to where they are independently adjustable, but I haven't had time or need to change that yet.
Glad it worked for you!
creat double door w/ adjustable swing
Mon, Apr 27, 2015 at 1:30:05 PM
Help help diagnosing double door with adjustable swings
Thu, Jun 11, 2015 at 3:35:52 PM
Adjustable angle door family
Thu, May 14, 2009 at 2:30:09 PM
Adding Sidelight to Double Door in Revit Architecture 2008
Fri, Aug 24, 2007 at 10:31:12 PM
Door parameters not scheduling or tagging in double door.
Mon, Sep 26, 2011 at 3:29:50 PM
Page generation time: 1.5730
