Forums >> Revit Building >> Technical Support >> Creating two surfaces for NGL & Finished, Poche Display
Mon, Mar 26, 2007 at 7:52:07 PM | Creating two surfaces for NGL & Finished, Poche Display
GEFC
Is there a easer way to create a NGL than creating a NGL surface tracing over the line in the elevations & sections then turning off the surface, then repating the process for the finished surface. When I create two surfaces in Revit the Poche from both the surfaces displays, where I only want the bottom surface Poche to display, and the top surface only to be displayed as a line.
Tue, Mar 27, 2007 at 9:26:04 AM | Creating two surfaces for NGL & Finished, Poche Display
rkitect
rkitect Avatar
4 Stars: 29 Votes
I'm not familiar with the term NGL, but I want to see if I know what you're talking about.  Could you tell me what NGL stands for?
Tue, Mar 27, 2007 at 5:58:27 PM | Creating two surfaces for NGL & Finished, Poche Display
GEFC
I am sorry I should of explained my self a bit better, NGL stands for Natural Ground Line (EXISTING). So what I am trying to do is to get two surfaces on one drawing, one for Natural Ground Line & one for Finished Ground Line. I can create the two surfaces all right but the problem is I only want one surface to display the hatch and the other surface to display as a line only no hatch.
revit 2016 poche
Wed, Sep 23, 2015 at 2:50:33 PM
Wall Poche and Phasing....
Wed, May 31, 2017 at 8:40:33 AM
Roofs and ceilings in Analytical Surfaces
Thu, Jun 2, 2011 at 11:12:47 AM
Poche Not Printing?
Tue, Sep 10, 2013 at 10:11:37 AM
Phasing & graphic overrides
Sun, Apr 18, 2010 at 12:25:14 AM
Page generation time: 1.4875
