Forums >> Revit Building >> Technical Support >> Keynote symbol question
Mon, Mar 26, 2007 at 1:34:29 PM | Keynote symbol question
blweisensel
I am wondering if it is possible to have a keynote with 2 leaders on it.  What I am trying to do is put a note on an elevation that is referencing a certain area as being removed.  I would like to put a note in that area that has 2 leaders on it, one going out and up from on side and one going out and down from the other side.  Is this possible or not.
Thanks
Mon, Mar 26, 2007 at 2:38:57 PM | Keynote symbol question
jron
I do not believe it is possible to add another leader to the keynote. What i do is just draw a line from the keynote to what or where ever I want it. I know that sounds archaic. But, it works. HTH
Mon, Mar 26, 2007 at 2:40:39 PM | Keynote symbol question
MrBob
3 Stars: 2 Votes
You should be able to click on the keynote and click the add leader button twice to get two leaders.
Mon, Mar 26, 2007 at 2:47:23 PM | Keynote symbol question
blweisensel
MrBob,
Where is this add leader button?  What I do is add the keynote, then detach the leader end and if I check and uncheck the leader button for the keynote, the leader just goes away and then comes back.
Thanks
Mon, Mar 26, 2007 at 3:22:24 PM | Keynote symbol question
MrBob
3 Stars: 2 Votes
I am using version 8.1.   When I add a keynote it gives me the option (in the option bar) to tell it how many leaders to add before I click it into the drawing.  After I put it in the drawing, I can click on it  and in the options bar are the add a leader and remove leader buttons.  Are you using keynotes or tags?
Mon, Mar 26, 2007 at 3:37:27 PM | Keynote symbol question
jron
In Revit 9.1 the key note symbols act just like the tag symbols. That is something that they changed in the upgrade.
Mon, Mar 26, 2007 at 4:10:48 PM | Keynote symbol question
TomDorner
4.5 Stars: 25 Votes
Keynotes were not available in Revit 8.1
MrBob is likely confusing Note Blocks with Keynotes.  Note Blocks are annotation symbols that can get scheduled in a Note Block schedule.  These are annotation symbols and can have multiple leaders added to them.
Keynotes in Revit 9.0/9.1 are based on a .txt file that holds keynote values tied into elements/materials or user fields. The keynote symbol can only have one leader or no leader.
Tom
www.reviteer.com   http://twitter.com/Reviteer
key noting symbol
Tue, Mar 2, 2010 at 10:41:19 PM
Keynote Question?
Thu, Apr 19, 2012 at 11:24:24 AM
Keynote Legend Question
Tue, Mar 23, 2010 at 2:42:11 PM
Custom symbol with wierd leader lines
Tue, Dec 3, 2013 at 2:09:28 PM
Material Keynote not working on window family
Tue, Nov 26, 2013 at 3:47:40 PM
Page generation time: 0.2381
