Forums >> General Discussion >> Revit Project Management >> Setting up for multi building projects?
Fri, Mar 23, 2007 at 9:35:16 AM | Setting up for multi building projects?
danbwall
Hi all...
I'm looking for some advice on how to setup for a subdivision project with 8 plus single family dwellings. How do others handle their projects as far as linking site data & topography? I am planning on setting up each house in an individual revit file, do I then also create a separate topography file and pull the topo into each house file? Or should I create the topo in each house file so that it will overlap into the next property a little bit, and then pull all of the houses into a common file and line them up there? Any tips/ tricks or advice would be much appreciated.
Tue, Mar 27, 2007 at 10:17:49 AM | Setting up for multi building projects?
rkitect
rkitect Avatar
4 Stars: 29 Votes
This is how I would do a project like this and how I would recommend anyone else do a project like similar to this.
I would do one topo file of the entire subdivision (break it into parts depending on the size of the subdivision) then create individual projects for the individual houses.  Link the  individual house projects into the site project.  Steve Stafford has a wonderful blog regarding this. It can be found here.
HTH, best of luck!
Tue, Mar 27, 2007 at 12:23:49 PM | Setting up for multi building projects?
danbwall
Thanks for that info. I had posted the same question on AUGI.com and got basically the same answer there, so I had better go with the wisdom of the masses... that blog article articulates the process just wonderfully. Thanks for that sir!
Wed, Mar 28, 2007 at 8:50:33 AM | Setting up for multi building projects?
rkitect
rkitect Avatar
4 Stars: 29 Votes
Don't thank me... thank Steve by buying his new book Winking
Edited on: Wed, Mar 28, 2007 at 8:50:43 AM
Tips on setting up a multi storey and multi unit residential model
Wed, Aug 3, 2011 at 8:35:26 AM
Setting up a Multi Storey building best practice for beginners
Fri, Oct 7, 2016 at 1:55:24 AM
Ramps unaffected by cutplane setting?
Wed, Oct 8, 2008 at 10:39:56 AM
Multi-building Schedule
Mon, Jun 9, 2008 at 3:43:31 PM
curious about size (s.f.) of revit projects?
Thu, Nov 17, 2005 at 11:22:07 AM
Page generation time: 1.1906
