Forums >> Revit Building >> Technical Support >> Rigid Insulation
Thu, Mar 22, 2007 at 3:10:39 PM | Rigid Insulation
send2lewis
I'm trying to draw a hatch pattern with fill region to show rigid insulation, however I can't find a suitable pattern.  Do anyone know how to add a pattern or to customize one?
Thu, Mar 22, 2007 at 6:48:30 PM | Rigid Insulation
framerman
4 Stars: 13 Votes
your help file does a pretty good job of explaining how to do  model and drafting patterns. If you have one from ACAD, then it's relatively easy to convert it. If you need something custom, then the hatchkit program has had a good reputation.
Fri, Mar 23, 2007 at 2:48:21 AM | Rigid Insulation
bdbhoy
1 Stars: 1 Votes
Go to draughting - detailed component - load ridged insulation and modify to width you reguire.
Rigid Insulation
Thu, Jan 10, 2008 at 8:33:53 AM
Slab Rigid Insulation
Wed, Nov 21, 2007 at 7:49:37 AM
two-way tapered rigid insulation
Mon, Feb 5, 2007 at 4:17:25 PM
complex roof - help!
Wed, Feb 27, 2008 at 11:57:23 AM
several keynotes on one object r2016
Thu, Aug 31, 2017 at 6:50:28 AM
Page generation time: 0.0250
