Forums >> General Discussion >> Revit Project Management >> why can't i delete lines in family edit mode?
Thu, Mar 22, 2007 at 1:09:21 PM | why can't i delete lines in family edit mode?
jwald
i'm trying to modify a window family and want to make the top curved but i can't delete the straight line when i am editing. i can draw new lines, just can't delete old ones. when i highlite it there is no padlock symbol, and in preferences i don't see anything about allowing modification. can anyone help? thank you!
Fri, Mar 23, 2007 at 1:07:03 PM | why can't i delete lines in family edit mode?
There is no way of telling, from your post, what straight line you are talking about.  Are you editing an extrusion, a symbolic lines .... maybe it is the opening cut?  When you select it, what does it say it is?
Wed, May 4, 2016 at 7:14:49 AM | why can't i delete lines in family edit mode?
vrmoreno3
Revit 2016 - Curious if this has ever been resolved or any further ideas. I too have had this problem. I am editing a annotation family and can't delete some lines.
Wed, May 4, 2016 at 7:26:03 AM | why can't i delete lines in family edit mode?
Need more information.....
Wed, May 4, 2016 at 7:36:49 AM | why can't i delete lines in family edit mode?
vrmoreno3
I used the existing north arrow and tried to modify it to create a new one. I ended up using the generic annotation which is a blank start.
Wed, May 4, 2016 at 8:03:18 AM | why can't i delete lines in family edit mode?
I have two stcok north arrows and since you did not ask a clear question, I took the time to load each and I could delete all linework.  So I still don't understand your question.  Obviously "existing north arrow"  is only existing to you.
In the future, please be clear and provide as much information as possible so we can answer.
Wed, May 4, 2016 at 8:49:53 AM | why can't i delete lines in family edit mode?
rbcameron2
rbcameron2 Avatar
4 Stars: 25 Votes
Are they not part of the family or the group?
RB Cameron
3D Medical Equipment
Download Revit Healthcare Models Now
Download Other Revit + 3dsMax Models Here
Mon, Jan 1, 2018 at 4:17:48 AM | why can't i delete lines in family edit mode?
Zrey
I have the same problem. I was trying to modify a fixed rectangle window to an ached wndow. Apparently I am able to delete the extrusion line at the top to change it to an arc line. I just could not do the same to the sketch line (Modify > Opening cut > Edit Boundary). Please advise. Usng Revit 2017.
Mon, Jan 1, 2018 at 6:26:55 PM | why can't i delete lines in family edit mode?
Opening cuts are all rectangles only.   If you need a different shape, you need to delete the opening cut and create a void using a sketch to cut the wall.   Be carefule here so that you cut the wall and not your element.
Can't exit sketch mode
Tue, Oct 22, 2019 at 7:19:00 AM
Family won't retain changes made in Edit Family mode
Tue, Feb 25, 2014 at 4:10:40 PM
finish edit mode tab issue
Fri, Aug 10, 2018 at 6:29:40 AM
Can I render in Family mode?
Mon, Mar 29, 2010 at 6:37:04 AM
Stairs Disappear upon edit sketch mode.
Wed, Jun 6, 2018 at 12:49:18 PM
Page generation time: 1.0612
