Forums >> Revit Building >> Technical Support >> Toposurface Elevation
Wed, Mar 21, 2007 at 4:43:23 PM | Toposurface Elevation
rkitect
rkitect Avatar
4 Stars: 29 Votes
I imported a survey from one of our projects into Revit to make a toposurface out of.  The elevations that it uses are in the range of 760-820 feet above sea level.  How can I:
a) bring the toposurface down to the elevation I need it at without going into autocad and changing all the z coordinates of the topo lines
b) create a base elevation level that sets the 0' bench mark for all other levels in the project.
Any ideas?  TIA
Thu, Mar 22, 2007 at 3:05:22 PM | Toposurface Elevation
pepsiqueen
pepsiqueen Avatar
in any elevation view you can move a toposurface up or down, but its not exact; it dosen't use snaps. you would have to know the numerical value to your 'zero', then just move it like you would anything else.
I'd rather be riding at whistler. or highland. thats good too.
Mon, Mar 26, 2007 at 8:03:00 AM | Toposurface Elevation
rkitect
rkitect Avatar
4 Stars: 29 Votes
This is what I ended up doing in the end.  Thanks for your help.  I used Steve Stafford's Topography blog on his website.
Thanks again!
Flat Toposurface
Thu, Aug 3, 2017 at 8:58:49 AM
Toposurface Elevation Base Point
Thu, Apr 28, 2016 at 4:35:51 PM
Toposurface is drawn at the wrong elevation relative to levels
Fri, Aug 4, 2017 at 12:09:48 PM
Toposurface glitch?
Thu, Jul 18, 2013 at 9:34:40 AM
how to view a toposurface with thickness in a elevation ou in a 3d view??
Thu, Jun 16, 2011 at 1:28:29 PM
Page generation time: 0.2204
