23 Users Online (21 Members):
Forums >> Revit Building >> Technical Support >> DIMENSION TICK MARKS
5 Posts No Rating |
How do I change the size of the dimension tick mark. I have them set at 3/32" with the scale set at 1/16". Is there a way to adjust them to be smaller according to the scale.
All annotation (including dimensions) is set to real world plotted size. Your 3/32" tick marks will always be 3/32" on the plotted page when plotted at 100% size. If you are trying to print plans at 1/16" that would normally want to be printed at 1/8", then I use a trick. I define a sheet with a titleblock that is twice the size I really need to place the 1/8" plan on. Then through the print setup reduce by 50%. For instance I have a 22"x34" titleblock to print larger plans down to 11"x17".
Heavy End Tick Marks disappear |
Thu, Jul 15, 2010 at 1:55:44 PM
MEP 2012 Electrical Tick Marks Problem |
Thu, May 26, 2011 at 4:46:24 PM
custom tick marks |
Sun, Dec 9, 2007 at 12:35:48 PM
dimension tick |
Wed, May 5, 2010 at 8:08:41 AM
Dimension with Tick and Dot |
Fri, May 21, 2010 at 10:36:20 AM
