9 Users Online (7 Members):
Forums >> Revit Building >> Technical Support >> Geo-Referencing
43 Posts No Rating |
Has anyone explored whether Revit projects can be geo-referenced (that is, given 'real world' coordinates, such as a lat & long)? I have been told that you can 'relocate' a project so that it inserts into correct position in relation to other linked projects, but what about using these 'real world' coordinates? For example, if I have a GPS point taken at a site to define a corner of a building, and want to use this to define the same corner on my project.
Another use for georeferenceing would to be able to auto-insert aerial images into files.
If this is not currently possible, I will certainly make the wish.
-Osir
Under the spot elevation tool is "spot co-ordinate". Use this only required corner, then edit the co-ordinates to what you require them to be (eg: 0,0)
4 Posts No Rating |
I know this is an old thread. However I am working on a project and I need to make my BIM model geo-referenced. I was provided with a point on the project that I need to set to the following location: EUREF89 596.550,000/6.642.730,000 I am not sure how to enter this information into Revit for "Specify Coordinates at a Point" option in Revit 2010 Revit wants you to enter something like: 596.550 / 642.730 Does anyone know how to enter the above EUREF89 location into Revit?
1 Posts No Rating |
Any news on this, "spot co-ordinate" does not use GPS points.
Linking CAD file with GEO Marker - RAC 2010 |
Wed, Sep 23, 2009 at 4:58:21 PM
Is their a way to change the Viewport referencing? |
Wed, Sep 21, 2016 at 3:16:25 PM
Referencing Array Groups? |
Tue, Dec 14, 2004 at 5:35:10 PM
Details not Referencing Backwards |
Tue, Mar 8, 2016 at 4:47:40 PM
Two Way Referencing |
Tue, Apr 20, 2010 at 7:01:13 PM
