Forums >> Revit Building >> Technical Support >> Issue Aligning two roofs that exist on different levels.
Mon, Mar 19, 2007 at 9:20:45 PM | Issue Aligning two roofs that exist on different levels.
kprossick
I am having an issue modifying roof geometry to meet my the design requirements in a residential project.
The issue is the roof over the garage where I have a hip roof structure trying to align with a front facing gable roof structure. The problem is that the hip roof is 3'-0" below the gable roof.
(see attachment for clarification)
I can get the right facing hip slope to align with the right facing gable slope, but as you can see, the hip extend out beyond the garage door wall too far. I wan't the right slope of the hip to terminate at the right gable fascia.
Any help would greatly be appreciated, Thanks.
 Keith
Shine On You Crazy Diamonds,
Keith Prossick
Tue, Mar 20, 2007 at 3:33:15 AM | Issue Aligning two roofs that exist on different levels.
kprossick
Please disregard this post.
 I was able to complete the roof geometry by creating each roof slope individually.
Keith Prossick
Tue, Mar 20, 2007 at 6:06:16 AM | Issue Aligning two roofs that exist on different levels.
xiqx
good you found it but I still would like to add a hint. If you run into something like that again use a reference plane.
good luck
Levels, Disappeared. [ 1 2 ]
Sun, Sep 24, 2017 at 7:44:33 AM
16
Two Ridge Roofs Issue
Sun, Feb 21, 2016 at 7:21:52 PM
roof intersections from multiple levels in a building
Fri, Aug 22, 2008 at 9:31:04 AM
Joining Roofs
Mon, Jan 21, 2013 at 7:42:56 PM
Find all levels
Thu, Aug 1, 2013 at 9:59:18 AM
Page generation time: 0.3424
