Forums >> Revit Building >> Technical Support >> Rendering Trees
Mon, Mar 19, 2007 at 2:08:34 PM | Rendering Trees
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
I am currently working on a rather large project, and in one of my camera views when I am zoom to fit it all on screen my trees do not render. Altho when I zoom in a region raytrace my trees show perfectly. It is very strange
Mon, Mar 19, 2007 at 4:14:36 PM | Rendering Trees
framerman
4 Stars: 13 Votes
I don't use the renderer in Revit, but from what I remember, you need to tell Revit what part you want rendered which I believe is what you have done. I don't think you can just click render and have it appear. You need to tell it what to render.
When you get frustrated with the renderer, there are free programs out on the internet that i feel does a better job. Accurender has some good points to it, but just doesn't cut the mustard when it comes to good looking stuff.
I have seen some excellent renderings though, just not good enough in my book. Didn't know if this would help you decide whether the rendering would be worth your time in revit.
Mon, Mar 19, 2007 at 4:42:40 PM | Rendering Trees
alabaster2513
3.5 Stars: 25 Votes
what other programs can you use?
 It just does not make sense to me that they render when im zoomed close but dont when zoomed all.
Mon, Mar 19, 2007 at 6:46:04 PM | Rendering Trees
TomDorner
4.5 Stars: 25 Votes
What size is your scene and what DPI have you set?  There is a 10,000 pixel limitation to Revit renderings.
Also, are you using the Accurender plants?  If yes, they are very heavy objects to render.  You are better off using RPC plant material from www.archvision.com
I wouldn't go outside of Revit to render until you have fully explored what is possible within Revit.  Most people have a hard time with rendering in any program.  Without proper scene setup, materials and lighting no rendering engine can do produce a decent rendering.
If you do go external to Revit, then Autodesk Viz is the first logical choice as it understands Revit's material settings.  Viz however is not cheap $2000 +/- and it is very complex.
Tom
www.reviteer.com   http://twitter.com/Reviteer
Mon, Mar 19, 2007 at 7:15:32 PM | Rendering Trees
alabaster2513
3.5 Stars: 25 Votes
well I have ADT 2007 & Viz. My render is 12"x7/5" at 600 dpi. They have rendered fine in the past. I just installed a ATI FireGL V7200 with recommended drivers and boosted another gig of ram on my dual 3 gig processor machine. From what I've seen done by other people this should be having no problems. My file size is about 70 MB on a 15 acre site with a 400,000 sq. ft building. I recently rendered 5 exhibits flawlessly. I am baffled.
rendering trees in winter???
Tue, Dec 14, 2010 at 5:46:53 AM
Rendering Trees in Revit 2010
Wed, Apr 27, 2011 at 2:53:37 PM
Revit 2012 problem rendering RPC trees
Tue, Sep 6, 2011 at 5:26:07 AM
rendering trees libaray
Wed, Jan 9, 2008 at 8:14:27 PM
Rendering Trees/Searching
Fri, Jun 17, 2011 at 2:49:30 PM
Page generation time: 2.3175
