Forums >> Revit Building >> Technical Support >> Later version... ?
Sun, Mar 18, 2007 at 12:35:02 PM | Later version... ?
adanedhel
4 Stars: 3 Votes
Hi i just downloaded new metric libraries, i guess they're for revit 9, while i've got revit 8.1. When i want to use something from it, the program says : The file (here goes the name) was saved in a later version of Autodesk Revit and cannot be retrieved in this version. I have no idea what to do with it. Is it like when i have earlier version i can't use libraries created for newer one ? Thanks for any replies and help. cheers
Sun, Mar 18, 2007 at 12:39:19 PM |
adanedhel
4 Stars: 3 Votes
Oh and I forgot to add that I downloaded the file from this page www.autodesk.com.
Sun, Mar 18, 2007 at 3:45:29 PM | Later version... ?
framerman
4 Stars: 13 Votes
Yes, it won't work. You have to download the 8.1 version which I believe is.....
http://revit.autodesk.com/Building/8.1/common/DownloadContent.asp?en-us
Edited on: Sun, Mar 18, 2007 at 3:58:28 PM
Mon, Mar 19, 2007 at 5:00:48 AM |
adanedhel
4 Stars: 3 Votes
Thanks man. I just hope it won't be the same library that i already have. Smile
revit latest version cannot be save to a lower version
Wed, Apr 27, 2011 at 10:00:25 AM
File in Student Version transfers to Professional Version
Mon, Jul 26, 2010 at 12:06:11 PM
Problem opening "component" version 9.1 in revit version 9.1
Fri, Jun 15, 2007 at 8:25:21 AM
CONSULTANT USING VERSION 12... IM USING VERSION 13...
Wed, Dec 19, 2012 at 9:52:05 AM
64 bit version
Wed, Nov 5, 2008 at 11:26:19 AM
Page generation time: 0.1122
