14 Users Online (12 Members):
Forums >> Revit Systems >> Technical Support >> Text TYPE PARAMETERS
I'm setting up a titleblock and am having some issues with parameters. I want to add/edit an existing text parameter (drawn by) so that it remains the same on every page, and I don't have to continually add in this information. I figured I could do it manually throught a txt file but I cannot find the origional parameter to copy. Can anyone help?
Edit your title block & change it per project is the easy fix.
I'm talking about a within project change. EX: the "drawn by" parameter I would have to put a name in for each sheet I create. The firm would rather have it so that that parameter is only entered in once, and appears on every page... similar to the way the project number and date stay on every page. I think I need to do this manually throught the .TXT file that is created when making a parameter.
As I said - modify your sheet.... take out the drawn by parameter and add the name you want to be on every sheet.
Maybe I'm not understanding you, sorry... You are saying to add in the drawn by parameter, then go to the properties menu and enter in the drawn by information once loaded- right? However, as I add multiple pages with that titleblock I loaded I continually have to go back to the properties (in the loaded block) and add in who has drawn the sheet (not the parameter "drawn by". As anal as it sounds, I would like it to be entered in once (sim. to the project # and date) and not have to add specifically who has drawn each individually sheet.
Type label question |
Fri, Jan 14, 2011 at 11:16:08 AM
RAC 2013 - Transfering wall parameters between projects |
Tue, Jun 25, 2013 at 11:58:23 AM
text box leader alignment |
Sun, May 9, 2010 at 7:48:44 AM
Shared Parameters |
Thu, Feb 9, 2006 at 1:41:58 PM
Category>Family>Type question re: text |
Wed, Jul 29, 2015 at 7:03:18 AM
