Forums >> Revit Building >> Technical Support >> Corrupted file
Fri, Mar 16, 2007 at 6:54:11 AM | Corrupted file
cirees0012
1 Stars: 1 Votes
how do you go about sending a corrupted file to autodesk to be analyse and repair
Thu, May 1, 2008 at 11:37:03 PM | Corrupted file
Fluffyfatcat
3.5 Stars: 3 Votes
i couldn't open my file in Revit 2009, contacted my dealer, they tried to open it and after they did not sicceed, they forwarded it to Autodesk. The file was repaired.
Fri, May 2, 2008 at 12:19:22 AM | Corrupted file
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Alternatively log into subscription centre, create a Support Request, request an FTP site, then upload your file and they''ll fix it then.  This bypasses your reseller.
Regards,
Chris.
Fri, May 2, 2008 at 1:39:57 PM | Corrupted file
mhans
3 Stars: 10 Votes
Oops. You normally have back-up saved somewhere. Depending on how often your back-up saves, you would at least get something. If you only need to try if Autodesk can fix it or not, hope for the worse. Check your Temp files (if your running XP). Rename back-up with permission if you are working in teams. If you are working in teams, chances are your team-mates might have saved something, somewhere.
Thanks,
Mhans
Motto: "No Post left behind"
a corrupted element
Wed, Apr 15, 2015 at 6:38:09 PM
Corrupted Files
Mon, Mar 24, 2008 at 10:51:35 AM
CORRUPTED ELEMENT in REVIT LT 2014
Thu, Feb 6, 2014 at 2:47:13 PM
Revit City Downloads Corrupted
Fri, Jul 10, 2015 at 9:21:31 AM
Imported hatch patterns appear corrupted
Thu, May 21, 2015 at 3:16:53 PM
Page generation time: 0.6387
