26 Users Online (24 Members):
Forums >> Revit Building >> Technical Support >> focuces on object
14 Posts No Rating |
i just imported a dwg object i see it on the 3d view but can't see it on the plan neither on elevation is there a command to zéro in on the object ? like the F key in Maya to move the view to the object for the plan and elevation thx
----------------------------------- perfect |
Type VP in either your plan view or elevation, scroll down and turn on your crop region & make crop region visible. This will show you the "Extends of your current window. Grab the handle and pull it out until you can see what you need to see.
thx that work but its strange that doesn't exist a center view to object even autocad got this i though but thx its ok
Embedded Detail Component and Object Styles |
Fri, Feb 12, 2010 at 3:21:25 PM
Object parameters |
Mon, Jul 28, 2008 at 12:53:06 PM
Object Style not showing unless object highlighted |
Thu, Jun 8, 2017 at 3:29:24 AM
keynoting hidden object |
Tue, Jul 6, 2010 at 1:48:09 PM
solid object from 3D dwg |
Thu, Apr 16, 2009 at 5:17:17 AM
