28 Users Online (26 Members):
Forums >> Revit Building >> Technical Support >> coordinates in shedule
You can show the coordinates of say a wall in your drawing through the spotdimensions. Is there a way that the begin and endpoint of a wall is displayed in a shedule. This way you can give the position of your wall in your shedule i.e. wall 01 grid A / 1-2 so wall 01 position is on grip A and between grid 1 en 2, you should acomplish this when you also know the coordinates of your grid.
Just curious, Did you find any workaorund/solution, yet? Thanks anyway, Renzo
You are not going to be able to do this with Revit out of the box. If you were to dive into the API you might stand a chance, but the biggest hurdle to overcome is that walls do not understand their relationship to grid lines.
1 Posts No Rating |
Please check below link for the solution
http://irevit.wordpress.com/2011/06/14/schedule-position-coordinates/
All about Revit & BIM
http://irevit.wordpress.com |
How to shedule just one Type? |
Mon, Apr 14, 2014 at 11:40:47 AM
specify coordinates at a point |
Tue, Oct 4, 2005 at 12:56:17 AM
Aquiring Coordinates |
Wed, Feb 10, 2010 at 10:22:37 AM
acquiring coordinates work |
Mon, Oct 3, 2005 at 12:54:34 PM
Shared Coordinates Published Incorrectly |
Mon, Jan 11, 2016 at 6:44:07 PM
