Forums >> Revit Building >> Technical Support >> Problem with Exporting to dwg with multiple layers for use in 3D Studio
Sat, Dec 11, 2004 at 6:59:55 AM | Problem with Exporting to dwg with multiple layers for use in 3D Studio
bearcjs22
I am exporting revit models to dwg for use in 3D studio. The problem I am having is that all walls come in on one layer, all roofs on one layer, all topo surfaces on one layer, and so on... So when i try to apply materials to brickwork walls, it also applys the same material to walls which I would like to be a different material. At the moment I am having to use multi sub-objects in 3D studio, but it is very time consuming to change the surface ID for the specific elements. Please help shed some light on this frustrating little problem. Thanks.
Mon, Dec 13, 2004 at 5:21:21 AM | RE: Problem with Exporting to dwg with multiple layers for use in 3D Studio
scappochin
You can have different layer for wall, only if you get different function (internal, external. foundation ecc) to every wall, and after in layer export you assign a different number (color) at every function on wall. The over way is to assign a modifer mesh to the layer when you import in Max or Viz.
Keep .dwg Layers when exporting .rvt to .dwgPlease
Wed, Feb 24, 2016 at 9:27:59 AM
Imported layers still active when exporting
Fri, Feb 26, 2010 at 8:44:40 AM
Exporting from Revit and into 3D Studio Max
Wed, Oct 31, 2007 at 1:25:11 AM
Keep layer names when exporting to DWG
Mon, May 13, 2013 at 7:48:10 AM
3D Studio Max 7 data exchange problem
Wed, Apr 20, 2005 at 2:29:13 AM
Page generation time: 1.8544
