Forums >> Revit Building >> Tips & Tricks >> white lines
Wed, Mar 14, 2007 at 2:55:07 PM | white lines
bhtarch
How do I make a white line?  I'm trying to cover up a line in plan that I don't want to show up.
Wed, Mar 14, 2007 at 3:08:05 PM | white lines
robinballew
robinballew Avatar
3 Stars: 4 Votes
I don't even want to know what you are covering up... You can use a filled region with a white fill and use the invisable line type to make the region. As a side not I'm sure there is a better way to do what ever it is...
BallewDesigns.com
Mon, Mar 19, 2007 at 11:16:25 AM | white lines
finale
what type of line are you trying to cover? where is it showing up at?
try clicking the "linework" icon on your toolbar and select (invisible lines) in your "type selector" pull down menu. Pan over the line you want and select.
use the same process and select (by category) to bring the line back.
Edited on: Mon, Mar 19, 2007 at 11:17:54 AMEdited on: Mon, Mar 19, 2007 at 11:21:44 AM
Edited on: Mon, Mar 19, 2007 at 11:26:06 AM
Mon, Mar 19, 2007 at 11:41:33 AM | white lines
bhtarch
Thanks to both of you.  Both suggestions will really come in handy!
White lines in section views
Mon, Jan 22, 2018 at 3:14:15 PM
elevation lines obscuring everything else (revit 2015)
Tue, Apr 14, 2015 at 2:05:53 PM
View image color
Tue, Aug 25, 2009 at 4:02:38 PM
Converting things to white
Thu, Dec 5, 2019 at 9:47:09 AM
White walls are dark grey when rendered?
Wed, Aug 10, 2005 at 10:57:54 PM
Page generation time: 0.2589
