Forums >> Revit Building >> Technical Support >> Getting a Rhinocerous 3.0 model into Revit?
Wed, Mar 14, 2007 at 2:11:59 PM | Getting a Rhinocerous 3.0 model into Revit?
DaveF
Hi
Has anyone managed to do this?
If so what method did do use?
Any tips & tricks would be appreciated.
Thanks
Dave F.
Wed, Mar 14, 2007 at 2:23:08 PM | Getting a Rhinocerous 3.0 model into Revit?
rodells
I believe the way to do this is to save the geometry out of Rhino into a 3D cad file (.dwg file) then import the model into a family.  (Create a new family, then use import/link and bring in the .dwg file).
As you no doubt know, Rhino is excellent for modeling the kinds of things not normally contemplated by the Revit toolset.  Organic shapes, etc. with high accuracy.
Wed, Mar 14, 2007 at 2:41:16 PM | Getting a Rhinocerous 3.0 model into Revit?
DaveF
Thanks for replying
I did this & got an error message:
Some numerical data within the imported file was out of range. Data has been truncated.
I made sure the dwg model was near 0,0,0.
Any ideas?
Cheers
Dave F.
Thu, Oct 15, 2009 at 3:41:31 PM | Getting a Rhinocerous 3.0 model into Revit?
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
you can import 3d surfaces, save the 3dm model as a sat file. Then in revit create a mass, import the sat file, and then use the mass tools(wall by face, floor by face, etc).
Thu, Oct 15, 2009 at 4:41:27 PM | Getting a Rhinocerous 3.0 model into Revit?
rodells
Yes, I just saw my post from 2 years ago and it offers bad advice, the .dwg format is a bad idea.
Rhino geometry imports flawlessly to Revit if you use the (ACIS) .sat file format.    The other key thing to remember is to import that geometry into the Family Editor, rather than directly into a Revit project.      (Start a new .rfa (family), select an appropriate family template, and import the .sat file.     You can define materials, etc. at that point.     Save the family and import the family into a revit project.)
can I model a rebar inside a model slab
Thu, Jan 10, 2013 at 12:29:27 PM
superimposing model on a photo or adding background to a model
Sat, Nov 29, 2008 at 1:40:22 AM
Door # in linked revit model not updating in main model
Tue, May 5, 2020 at 5:54:10 PM
How do I move Model to align with linked Architect's model?
Mon, Sep 19, 2011 at 12:41:29 PM
Importing a 3d autoCAD model - preserve individual 3d elements in model
Wed, Apr 21, 2010 at 1:29:11 PM
Page generation time: 2.9980
