Forums >> Revit Building >> Technical Support >> Can't place windows and don't know why
Tue, Mar 13, 2007 at 11:32:35 PM | Can't place windows and don't know why
huey
When I try to place a window i get the following error message and I dont know what i,ve done wrong. Can someone help. I am a beginner at revit.
The message is as follows: can't make type dhung3...
None of the created elements are visible in floor plan view. You may want to check the active views, its parametersa and visibility settings as well as any plan region and their settings
 Have I done something that I shouldn't have done.... Please help getting very frustrated
Tue, Mar 13, 2007 at 11:53:31 PM | Can't place windows and don't know why
psymon
psymon Avatar
3.5 Stars: 6 Votes
It sounds like there is an error in the family. Please attach the file to a reply for people to look at.
Did you make the window? Where did it come from?
Wed, Mar 14, 2007 at 6:08:48 AM | Can't place windows and don't know why
robinballew
robinballew Avatar
3 Stars: 4 Votes
also try placing the window in 3D. Some time the default settings in the windows will be at 20' so it will not place it in plan..
BallewDesigns.com
Wed, Mar 14, 2007 at 6:20:42 AM | Can't place windows and don't know why
coreed
coreed Avatar
4 Stars: 16 Votes
check the base offset in the properties button before you place the window. it could be set a lot higher that the current level cut plane and it would not be visible when you place it.
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
BEWARE - Parameters don't update.
Thu, Sep 1, 2005 at 11:36:58 PM
'forms' not available in 'in place mass' or components.please help
Fri, Aug 30, 2013 at 3:20:58 AM
'Out of Memory' pop up
Tue, Sep 6, 2005 at 3:16:07 PM
window opening doesn't show in floor plan view
Mon, Oct 3, 2005 at 7:59:15 PM
''Visibility grafics'' and ''create parts'' problem when mak
Fri, Mar 19, 2021 at 11:45:46 AM
Page generation time: 3.0207
