Forums >> Revit Building >> Technical Support >> Baluster Placement
Tue, Mar 13, 2007 at 6:00:30 PM | Baluster Placement
corey0523
I have an L shaped guardrail that turns 90 degrees and dies into a wall at the short leg of the guardrail and is less than 8'-0". The baluster spacing is set at 4'-0" o.c. Is there a way to adjust the middle baluster on the short leg of the guardrail to be centered without changing the rest of the balusters?
Handrail Deletes when adjusting baluster placement?
Tue, Aug 27, 2013 at 8:03:27 PM
Simple Baluster Placement Not simple?
Tue, Oct 16, 2012 at 7:42:43 AM
Baluster inside Newel Post revit 2014
Wed, Mar 26, 2014 at 2:54:06 AM
baluster placement in stairsteps
Thu, Mar 28, 2013 at 7:16:26 AM
Baluster Placement Parameter
Wed, Sep 10, 2008 at 11:38:07 AM
Page generation time: 1.2988
