Forums >> Revit Building >> Technical Support >> rock veneer wall
Tue, Mar 13, 2007 at 2:53:51 PM | rock veneer wall
entropies
How can I make a wall out of CMU and cover that with a rock face?
I can use the brick on CMU but cannot seem to find a way to do it with rock.
Any suggestions?
Thanks
Tue, Mar 13, 2007 at 6:12:49 PM | rock veneer wall
Dgodfrey
4 Stars: 4 Votes
If you need a hatch pattern for drafting views, you can create new from the materials dialogue|surface pattern. Browse for a .pat file that fits your needs. Cultured stone (owens-corning) offers a bunch and i think they are still free. If you want the stone to render, use the accurender materials OOTB, not much to pick from though. If you want more options, go to www.accustudio.com
Sat, Feb 23, 2008 at 9:53:02 PM | rock veneer wall
rchoutka
1 Stars: 1 Votes
What I think you want is a CMU wall that has a Stone Facade attached to the front of it. ( Exterior one would need airspace?)  Go to the wall ELEMENT BOUNDARIES and ADD a Stone Wall ( 4" thick or whatever ) to outside of the Core Boundary on the EXTERIOR FACE, then assign a stone hatch patttern as required.
HTH,
Rob
Need really a good looking rock material!
Mon, Sep 1, 2008 at 2:04:24 AM
Stone Wall
Tue, Aug 20, 2013 at 3:55:33 PM
Rock Wall Modelling
Sun, Jan 2, 2011 at 8:21:55 PM
Stone Veneer and Framing Plan
Wed, Nov 14, 2007 at 12:12:22 PM
BRICK VENEER WALL
Fri, Jul 22, 2005 at 8:55:04 AM
Page generation time: 0.8956
