Forums >> Revit Structure >> Technical Support >> Array being a parameter in a family?
Tue, Mar 13, 2007 at 1:17:03 PM | Array being a parameter in a family?
WYSIWYG
3 Stars: 2 Votes
I am making a footrail starting with a floor support 6" from the left reference plane and repeating every 36".  I would like user to be able to pick the beginning and end points and Revit to decide how many footrails need to be there.  Is this possible?  I've scoured the Revit help files and couldn'tfind what I needed, I think.  I did find repeating a detail component but this was not an option in the family editor.  I also checked out the array turorial on this site but didn't quite understand how to appy it to this situation.  Thanks for yoiur help.
Tue, Mar 13, 2007 at 1:58:57 PM | Array being a parameter in a family?
WYSIWYG
3 Stars: 2 Votes
Oops - that would be "backets need to be there".  I've tried coping the first bracket and added a paremeter this formula to the parameter
Parameter: Graphics Value: 2  Formula: (Bracket Spacing/3' 0"Winking + 1
but I'm not sure I'm going about it in the right way.  Am I?  I get an "inconsistant Units" error message.
Wed, Mar 14, 2007 at 9:11:23 AM | Array being a parameter in a family?
lpromana
4 Stars: 2 Votes
you could look into two tutorials to create a family based on the "generic model line based" family template, sadly within the software there is no specific guidelines for this family creation but if you read on the 2d line base family and also review the creation of the parametric family and nested families in the tutorials that should help you, you need to combine the knowledge for the 2pick families with the way they greate the array of the webs in the truss in the parametric family. I hope this is of any help
Wed, Mar 14, 2007 at 11:51:02 PM | Array being a parameter in a family?
psymon
psymon Avatar
3.5 Stars: 6 Votes
Have a look at this blog:
http://revit-alize.blogspot.com/2006/04/two-pick-or-not.html
 It helped me heaps to understand arrays in families. I recommend doing the exercise, not just reading it. See how you go.
Array Parameter within Family
Thu, Aug 7, 2014 at 8:25:09 AM
Centering an Array Parameter within a Family (Wall Based)
Fri, May 4, 2012 at 5:06:22 PM
Array Distance Parameter
Thu, Apr 11, 2019 at 8:53:57 AM
Array Parameter
Tue, Apr 27, 2010 at 11:18:05 AM
Radial Array in a Family
Mon, Apr 11, 2005 at 8:56:12 PM
Page generation time: 1.9845
