Forums >> Revit Building >> Technical Support >> NEON LIGHTING
Tue, Mar 13, 2007 at 12:10:37 PM | NEON LIGHTING
TEDABBOTT
CAN ANYONE TELL ME WHAT THE BEST WAY TO GO ABOUT CREATING NEON LIGHT LETTERS WOULD BE. IVE TRIED CREATING FLOURESCENT LIGHT FIXTURES BUT HAVENT FIGURED OUT HOW TO MAKE THE WHOLE OBJECT LIGHT UP. IT SEEMS THAT ONLY ONE POINT WILL LIGHT UP. CAN ANYONE HELP ME WITH THIS?
Tue, Mar 13, 2007 at 12:29:15 PM | NEON LIGHTING
Enginator
5 Stars: 2 Votes
For white lights, there is a texture under "revit" in the Accurender materials for a luminescent white color.  You may be able to edit that for a luminescent color other than white.
Thu, Jun 14, 2007 at 9:28:40 AM | NEON LIGHTING
Snoof
I don't think you can actually create lights that truly emit coloured light i.e neons. so i generally create an object (extrusion sweep along path) and then create a material that has self illumination set high so that it appears to be glowing. i then put a light source behind it... if you create a coloured glass 'bulb' around a light then it will take on the colour as it passes through if that makes sense. I'm hoping that evntualy when they replace the Accurender engine with Mental Ray (Im sure this is coming) then we will be able to create lights as we can in VIZ and Max
Thu, Jun 14, 2007 at 9:35:56 AM | NEON LIGHTING
chudy
1 Stars: 1 Votes
Snoof do you know when they are going to put Mental Ray in Revit? Cause renders from AccuRender don't look too good. If Mental Ray would be built in Revit there wouldn't be a problem with exporting etc.
Heh I just can't wait to have MR in Revit Puh
Fri, Jun 29, 2007 at 1:43:42 AM | NEON LIGHTING
Snoof
I not too sure when they will put it in as I believe that they have a commitment to use Accureneder for a certain time frame...though there have been a lot of rumours recently.... I can't see them using Accurender for much longer as it makes much more sense for them to use their own render engine as it's better and also cheaper for them to do this, plus it will bring it in-line with all their other products. I'm really hoping that the next release will have it, but guess we will have to wait and see..... I still export my Revit models and bring them into Max to create quality renders... I only use the Accurender engine for quick visuals.
Neon signs
Mon, Dec 17, 2012 at 8:01:37 AM
Neon/ Glow in the Dark Signs/Lettering Anyone
Tue, Oct 28, 2008 at 8:16:26 AM
Project Neon
Sun, Aug 7, 2011 at 7:58:32 AM
how to put neon light on facade ?
Fri, Apr 8, 2016 at 9:25:00 AM
LED Lighting strips in Soffits
Mon, Jun 8, 2009 at 3:25:01 PM
Page generation time: 1.2127
