Forums >> Revit Building >> Technical Support >> Model Hatch Pattern - Align
Mon, Mar 12, 2007 at 3:03:09 PM | Model Hatch Pattern - Align
chimso
I have a multistory building with a masonry structure below, and metal framing above. The exterior finish is the same on both substrates, and the hatch pattern is using the same pat file, but for some reason, they don't align. it is a batten hatch, so I was wondering if there is any way to shift the pattern so it aligns with the walls below. Thanks for the help. see attached image showing the offset in battens.
Mon, Mar 12, 2007 at 3:45:55 PM | Model Hatch Pattern - Align
robinballew
robinballew Avatar
3 Stars: 4 Votes
You can use the Align command to fix it. Just tab through untill it highlights the hatch..
BallewDesigns.com
Vertical hatch pattern line alignment on wall ends
Wed, Mar 14, 2012 at 10:04:07 AM
Aligning hatch pattern on elevations
Thu, Mar 6, 2008 at 9:11:59 AM
Hatch 22- Curve Pattern
Wed, May 30, 2018 at 4:07:07 PM
Model Pattern Not Moving Independently
Wed, Dec 5, 2012 at 2:13:37 PM
Floor pattern not showing up when the pattern is model pattern
Fri, Nov 3, 2023 at 9:11:59 PM
Page generation time: 3.5821
